Ana içeriğe geç
Acer Aspire 5251-1513 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 5251-1513 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Aspire 5251-1513 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire 5251-1513 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Hard Drive Replacement: adım 4, 2 resimden 1. Acer Aspire 5251-1513 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Hard Drive Replacement: adım 6, 2 resimden 1. Acer Aspire 5251-1513 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 Hard Drive Replacement: adım 7, 2 resimden 1. Acer Aspire 5251-1513 Hard Drive Replacement: adım 7, 2 resimden 2.
    • Slide the hard drive to the left until it clicks and then pull it out completely.
  8. Acer Aspire 5251-1513 Hard Drive Replacement: adım 8, 3 resimden 1. Acer Aspire 5251-1513 Hard Drive Replacement: adım 8, 3 resimden 2. Acer Aspire 5251-1513 Hard Drive Replacement: adım 8, 3 resimden 3.
    • Unscrew the four 3.6 mm screws on either side of the casing with the Phillips #0 screwdriver.
    • Remove the hard drive out of its casing.
    • Be Gentle with the hard rive, only touch the edges.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gicely Rodriguez
1.029 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Spring 2019 USF Tampa, Team S1-G6, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 574
