Ana içeriğe geç
Acer Aspire 5251-1513 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire 5251-1513 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Motherboard Replacement: adım 2, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 2, 2 resimden 2.
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Motherboard Replacement: adım 3, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 3, 2 resimden 2.
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Motherboard Replacement: adım 4, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Unscrew the 8.6 mm screws on the back panel with a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Motherboard Replacement: adım 6, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, lift up the panel and remove it completely.
  7. Acer Aspire 5251-1513 Motherboard Replacement: adım 7, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 7, 2 resimden 2.
    • Flip the laptop over as shown.
    • Locate the six tabs keeping the keyboard in place.
    • The tabs are hard to see because they are in-between the keys and the top cover but if you look close, there are black tabs you can push in so they are invisible.
  8. Acer Aspire 5251-1513 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull on the edge of the keyboard using a spudger or your hands.
    • As you pull on the keyboard, push the tabs in one by one using small tweezers.
    • The keyboard may feel like its bending as you pop it out, but don't worry.
  9. Acer Aspire 5251-1513 Motherboard Replacement: adım 9, 1 resimden 1.
    • Once you pop it out and its separated, slowly turn it over to reveal its attachment to the connector.
    • Do not pull the keyboard out too hard because you risk damaging both the connector and the laptop.
  10. Acer Aspire 5251-1513 Motherboard Replacement: adım 10, 1 resimden 1.
    • Using tweezers, slide the the tab down. This will release the connector that you can gently pull out of the socket.
    • If it does not come out easily, then you did not release it with the tabs and you risk ripping the connector.
  11. Acer Aspire 5251-1513 Motherboard Replacement: adım 11, 1 resimden 1.
    • Once freed, remove the keyboard entirely and put it aside.
  12. Acer Aspire 5251-1513 Motherboard Replacement: adım 12, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 12, 2 resimden 2.
    • Flip the computer gently so that the back is facing you.
    • Remove all 12 of the 7.6 mm screws on the backside with a Phillips #0 screwdriver.
    • Remove 4 of the 5.4 mm screws on the backside with a Phillips #00 screwdriver.
  13. Acer Aspire 5251-1513 Motherboard Replacement: adım 13, 1 resimden 1.
    • Flip the computer back over.
    • Unscrew the seven 5.6 mm screws located on the top cover using a Phillips #0 screwdriver.
  14. Acer Aspire 5251-1513 Motherboard Replacement: adım 14, 1 resimden 1.
    • Locate the 4 connectors that must also be disconnected.
  15. Acer Aspire 5251-1513 Motherboard Replacement: adım 15, 1 resimden 1.
    • Disconnect the connector using tweezers to pull down the brown tabs.
    • For the smaller right and left speaker cables, pull out the black tab completely also using tweezers.
  16. Acer Aspire 5251-1513 Motherboard Replacement: adım 16, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 16, 2 resimden 2.
    • Using a plastic spudger or your hands, carefully lift up the corner of the top panel.
    • Continue to lift the panel until it is removed completely.
  17. Acer Aspire 5251-1513 Motherboard Replacement: adım 17, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 17, 2 resimden 2.
    • For the video cable connector, use tweezers to pull up on the white tabs to release the connector.
    • Remove the remaining connectors using the same technique from previous steps: pull on brown tabs using a tweezer.
  18. Acer Aspire 5251-1513 Motherboard Replacement: adım 18, 1 resimden 1.
    • Unscrew the 5.6 mm screws keeping the motherboard in place using a Phillips #0 screwdriver.
  19. Acer Aspire 5251-1513 Motherboard Replacement: adım 19, 1 resimden 1.
    • Lift up the motherboard from its base slowly.
    • Please be careful because the motherboard is still attached to the computer through a DC Jack cable.
  20. Acer Aspire 5251-1513 Motherboard Replacement: adım 20, 2 resimden 1. Acer Aspire 5251-1513 Motherboard Replacement: adım 20, 2 resimden 2.
    • Disconnect the cable attached to the bottom of the motherboard.
    • Pull on the brown tab using tweezers until its completely disconnected and remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Gicely Rodriguez
1.029 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Spring 2019 USF Tampa, Team S1-G6, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G6
4 Üyeler
Bir Yorum
ola tudo bem?
voce sabe a ultima versao da bios?
julio garcia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 1,370
