Ana içeriğe geç
Acer Aspire 5253 RAM Replacement
Neye ihtiyacın var
    1. Acer Aspire 5253 RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the laptop over.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Aspire 5253 RAM Replacement: adım 2, 1 resimden 1.
      • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Aspire 5253 RAM Replacement: adım 3, 1 resimden 1.
      • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Aspire 5253 RAM Replacement: adım 4, 1 resimden 1.
      • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
      FixBot'a Sor
      Yorum Ekle
    5. Acer Aspire 5253 RAM Replacement: adım 5, 1 resimden 1.
      • You have successfully removed the battery. Congratulations!
      FixBot'a Sor
      Yorum Ekle
    1. Acer Aspire 5253 RAM Replacement, Back Cover Panel: adım 6, 1 resimden 1.
      • Now, locate the two screws that hold the back cover panel onto the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Aspire 5253 RAM Replacement: adım 7, 1 resimden 1.
      • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
      • The screws are 3/8" in length and have a 1/4" head.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Aspire 5253 RAM Replacement: adım 8, 2 resimden 1. Acer Aspire 5253 RAM Replacement: adım 8, 2 resimden 2.
      • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Aspire 5253 RAM Replacement: adım 9, 1 resimden 1.
      • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Acer Aspire 5253 RAM Replacement, RAM: adım 10, 1 resimden 1.
      • Now, locate the RAM.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Aspire 5253 RAM Replacement: adım 11, 1 resimden 1.
      • Locate the two metal pieces on both sides of the RAM that are holding it in place.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Aspire 5253 RAM Replacement: adım 12, 1 resimden 1.
      • Pull the tabs apart to remove the RAM.
      • The RAM will pop up once they are pried open.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Aspire 5253 RAM Replacement: adım 13, 2 resimden 1. Acer Aspire 5253 RAM Replacement: adım 13, 2 resimden 2.
      • Carefully slide the RAM out of the compartment.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Cynthia Barajas
2.258 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G11
4 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
nhanblack1996 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 54
Her zaman: 4,547
