Ana içeriğe geç
Acer Aspire 5334-2581 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire 5334-2581 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Keyboard Replacement: adım 2, 1 resimden 1.
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Keyboard Replacement: adım 3, 1 resimden 1.
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Keyboard Replacement: adım 4, 1 resimden 1.
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: adım 5, 3 resimden 1. Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: adım 5, 3 resimden 2. Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: adım 5, 3 resimden 3.
    • The keyboard is held underneath a plastic cover. remove this cover with a spudger.
    • Using a spudger, apply it underneath the keyboard and lift it up.
  6. Acer Aspire 5334-2581 Keyboard Replacement: adım 6, 2 resimden 1. Acer Aspire 5334-2581 Keyboard Replacement: adım 6, 2 resimden 2.
    • Disconnect the keyboard flex cable, and now you are ready to install a new keyboard.
    • Take extra care, and try not to break the the latch that holds the cable in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
gilson teixeira
334 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 701
