Ana içeriğe geç
Acer Aspire 5334-2581 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire 5334-2581 RAM  Replacement, Battery: adım 1, 1 resimden 1.
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 RAM  Replacement: adım 2, 1 resimden 1.
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 RAM  Replacement: adım 3, 1 resimden 1.
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 RAM  Replacement: adım 4, 1 resimden 1.
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 RAM  Replacement, RAM: adım 5, 1 resimden 1.
    • Remove the phillips screw
    • then take away the cover
  6. Acer Aspire 5334-2581 RAM  Replacement: adım 6, 1 resimden 1.
    • Push the marked claws to the side in order to make the RAM free.
    • To remove the RAM just pull it in the shown direction.
    • Take extra care when removing the RAM, you do not want to damage the placeholder for the RAM.
Sonuç
Bir başkası bu kılavuzu tamamladı.
gilson teixeira
334 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 303
