Ana içeriğe geç
Acer Aspire 5334-2581 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 5334-2581 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Screen Replacement: adım 2, 1 resimden 1.
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Screen Replacement: adım 3, 1 resimden 1.
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Screen Replacement: adım 4, 1 resimden 1.
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  6. Acer Aspire 5334-2581 Screen Replacement: adım 6, 1 resimden 1.
    • With a spudger, release the clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom, there are cable connections, and you don't want to damage them
  7. Acer Aspire 5334-2581 Screen Replacement: adım 7, 1 resimden 1.
    • With caution disconnect the camera cable.
  8. Acer Aspire 5334-2581 Screen Replacement: adım 8, 2 resimden 1. Acer Aspire 5334-2581 Screen Replacement: adım 8, 2 resimden 2.
    • Remove the 4 screws in the side of the LCD. Screen should be able to come of the frame
  9. Acer Aspire 5334-2581 Screen Replacement: adım 9, 1 resimden 1.
    • Take the screen and flip on top of the keyboard.
    • Unplug the cable connected to the video card.
    • Don't use too much force, you don't want to damage this component.
  10. Acer Aspire 5334-2581 Screen Replacement: adım 10, 2 resimden 1. Acer Aspire 5334-2581 Screen Replacement: adım 10, 2 resimden 2.
    • Remove the tape, and unplug the display cable.
    • Unstick the cable from the back of the LCD, and now the LCD is free to come off. You are ready to install a new one
    • Try not to damage this cable, otherwise replacing it would be so much pain.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
gilson teixeira
334 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Catania Fall 2016 UMass Dartmouth, Team 1-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 361
