Ana içeriğe geç
Acer Aspire 5336-2524 Hard drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 5336-2524 Hard drive Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire 5336-2524 Hard drive Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire 5336-2524 Hard drive Replacement, Battery: adım 1, 3 resimden 3.
    • Flip over the laptop.
    • Make sure the battery lock is pushed down so the red part is exposed.
    • Push the switch all the way to the side and that will push the battery up.
    • Remove the battery.
  2. Acer Aspire 5336-2524 Hard drive Replacement, Hard drive: adım 2, 2 resimden 1. Acer Aspire 5336-2524 Hard drive Replacement, Hard drive: adım 2, 2 resimden 2.
    • Remove the two M2.5x8 screws with a Phillips #0 screwdriver.
    • Use the plastic iFixit opening tool to pry open the lower door.
  3. Acer Aspire 5336-2524 Hard drive Replacement: adım 3, 3 resimden 1. Acer Aspire 5336-2524 Hard drive Replacement: adım 3, 3 resimden 2. Acer Aspire 5336-2524 Hard drive Replacement: adım 3, 3 resimden 3.
    • Put slight pressure on the hard drive and slide it to the left.
    • Now pull the hard drive out.
  4. Acer Aspire 5336-2524 Hard drive Replacement: adım 4, 3 resimden 1. Acer Aspire 5336-2524 Hard drive Replacement: adım 4, 3 resimden 2. Acer Aspire 5336-2524 Hard drive Replacement: adım 4, 3 resimden 3.
    • Remove both M2.5x8 screws on each side of the hard drive caddy, using a Phillips #0 screwdriver.
    • Lift the hard drive out of the caddy.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Carlin Sullivan
695 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Valliere Fall 2019 UMass Dartmouth, Team S1-G4, Valliere Fall 2019 üyesi
UMASSD-VALLIERE-F19S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,544
