Ana içeriğe geç
Acer Aspire 5336-2524 Motherboard Replacement
Neye ihtiyacın var
Öne Çıkan Belge
  1. Acer Aspire 5336-2524 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire 5336-2524 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Flip over the laptop.
    • Make sure the battery lock is pushed down so the red part is exposed.
    • Push the switch all the way to the side and that will push the battery up.
    • Remove the battery.
  2. Acer Aspire 5336-2524 Motherboard Replacement, DVD/CD Drive: adım 2, 1 resimden 1.
    • Remove the M2.5x8 screw using a Phillips #0 screwdriver.
  3. Acer Aspire 5336-2524 Motherboard Replacement: adım 3, 2 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 3, 2 resimden 2.
    • Slide the DVD/CD drive out of the laptop.
  4. Acer Aspire 5336-2524 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Flip over the laptop and remove all eleven of the M2.5x8 screws on the bottom of the laptop with a Phillips #0 screwdriver.
    • Remove all four of the M2x3 screws with a Phillips #0 screwdriver.
  5. Acer Aspire 5336-2524 Motherboard Replacement: adım 5, 1 resimden 1.
    • Pry open the lower door on the bottom of the laptop using the iFixit opening tool.
  6. Acer Aspire 5336-2524 Motherboard Replacement: adım 6, 3 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 6, 3 resimden 2. Acer Aspire 5336-2524 Motherboard Replacement: adım 6, 3 resimden 3.
    • Put slight pressure on the hard drive and slide it to the left.
    • Now pull the hard drive out.
  7. Acer Aspire 5336-2524 Motherboard Replacement: adım 7, 3 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 7, 3 resimden 2. Acer Aspire 5336-2524 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the M2x3 screw on the wireless card with a Phillips #0 screwdriver.
    • Remove the wireless card antennas by lifting straight up on the base of the connection.
    • Remove the battery underneath the wireless card.
    • Remove the RAM modules by pushing the springs on the side and lifting up.
  8. Acer Aspire 5336-2524 Motherboard Replacement: adım 8, 3 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 8, 3 resimden 2. Acer Aspire 5336-2524 Motherboard Replacement: adım 8, 3 resimden 3.
    • Open the laptop.
    • Wedge the spudger or iFixit opening tool between the side of the keyboard and the laptop and apply a slight amount of upward pressure.
    • Push in the latches at the top of the keyboard using the spudger to release that part of the keyboard, and start to lift up the keyboard more and more as you push in the latches.
    • Remove the ribbon cable that connects the keyboard to the motherboard by pushing the black latch downward and then pulling the cable out.
  9. Acer Aspire 5336-2524 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the eight M2.5x8 screws with a Phillips #0 screwdriver.
    • Remove the cables indicated by simply pulling them out.
    • Remove the cables by lifting up on the black latch and pulling the ribbon out.
  10. Acer Aspire 5336-2524 Motherboard Replacement: adım 10, 2 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 10, 2 resimden 2.
    • Use the iFixit opening tool to start to pry open the laptop case.
    • Flip over the laptop and open the screen.
    • Finish opening up the case.
  11. Acer Aspire 5336-2524 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the cable by lifting the black latch and pull the ribbon out.
    • Verify that the other cables are fully unplugged.
  12. Acer Aspire 5336-2524 Motherboard Replacement: adım 12, 2 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove M2.5x8 screw with a Phillips #0 screwdriver.
  13. Acer Aspire 5336-2524 Motherboard Replacement: adım 13, 2 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 13, 2 resimden 2.
    • Lift the motherboard up and unplug the fan.
  14. Acer Aspire 5336-2524 Motherboard Replacement: adım 14, 3 resimden 1. Acer Aspire 5336-2524 Motherboard Replacement: adım 14, 3 resimden 2. Acer Aspire 5336-2524 Motherboard Replacement: adım 14, 3 resimden 3.
    • Now replace the motherboard with a new one and follow the steps in reverse to assemble the laptop with the new motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carlin Sullivan
695 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Valliere Fall 2019 UMass Dartmouth, Team S1-G4, Valliere Fall 2019 üyesi
UMASSD-VALLIERE-F19S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,306
