Ana içeriğe geç
Acer Aspire 5349-2592 Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire 5349-2592 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Fan Replacement: adım 2, 1 resimden 1.
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Fan Replacement: adım 3, 1 resimden 1.
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Fan Replacement: adım 4, 1 resimden 1.
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Fan Replacement, Back plate: adım 5, 1 resimden 1.
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Fan Replacement: adım 6, 1 resimden 1.
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Fan Replacement, CD / DVD Drive: adım 7, 1 resimden 1.
    • Unscrew the single screw on the DVD drive with your Phillips #0 screwdriver.
  8. Acer Aspire 5349-2592 Fan Replacement: adım 8, 1 resimden 1.
    • Gently lift the drive up and remove it from the pin.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Abderahmane Naidjate
547 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Spring 2019 UMass Dartmouth, Team S1-G3, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 336
