Ana içeriğe geç
Acer Aspire 5349-2592 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 5349-2592 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Open the laptop so that the screen is facing you.
  2. Acer Aspire 5349-2592 Screen Replacement: adım 2, 1 resimden 1.
    • Pull of the plastic frame of the laptop screen.
  3. Acer Aspire 5349-2592 Screen Replacement: adım 3, 1 resimden 1.
    • Unscrew the 1/4'' screws at each of the corners using a Phillips screwdriver
    • Pull off the screen from the device. If necessary, you may use a bezel provided by the iFixit tool kit.
    • Handle the Acer 5349-2592 LCD hinges with care as they are delicate.
Sonuç
Abderahmane Naidjate
547 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Spring 2019 UMass Dartmouth, Team S1-G3, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G3
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
your description is extremely lacking, the two screws near the hinges, and connections.
ComputerGuy Wilkes-Barre - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 673
