Ana içeriğe geç
Acer Aspire 5517-1127 Disk Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 5517-1127 Disk Drive Replacement, Disk Drive: adım 1, 2 resimden 1. Acer Aspire 5517-1127 Disk Drive Replacement, Disk Drive: adım 1, 2 resimden 2.
    • Orient the laptop so that its upside down facing away from you.
    • The screw is at the bottom of the RAM panel.
  2. Acer Aspire 5517-1127 Disk Drive Replacement: adım 2, 2 resimden 1. Acer Aspire 5517-1127 Disk Drive Replacement: adım 2, 2 resimden 2.
    • Using a Phillips screwdriver (PH1), unscrew the screw from the panel.
    • Pull the panel away from the device as shown.
  3. Acer Aspire 5517-1127 Disk Drive Replacement: adım 3, 3 resimden 1. Acer Aspire 5517-1127 Disk Drive Replacement: adım 3, 3 resimden 2. Acer Aspire 5517-1127 Disk Drive Replacement: adım 3, 3 resimden 3.
    • The screw to the right of the inner RAM casing is shown.
    • Using the same Phillips screwdriver (PH1), unscrew the screw.
  4. Acer Aspire 5517-1127 Disk Drive Replacement: adım 4, 3 resimden 1. Acer Aspire 5517-1127 Disk Drive Replacement: adım 4, 3 resimden 2. Acer Aspire 5517-1127 Disk Drive Replacement: adım 4, 3 resimden 3.
    • Gently push the disk drive away from the device as demonstrated.
    • The disk drive will come out with the screw removed from the RAM casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Newkirk
509 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-1, Blackwell Spring 2017 USF Tampa, Team 17-1, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 350
