Giriş
This guide will walk you through how to replace a disk drive on your Acer Aspire 5517-1127 device. If your device is not recognizing or reading disks when inside the disk drive, this guide may be able to assist you.
Neye ihtiyacın var
Orient the laptop so that its upside down facing away from you.
The screw is at the bottom of the RAM panel.
Bir başkası bu kılavuzu tamamladı.
