Ana içeriğe geç
Acer Aspire 5517-1127 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire 5517-1127 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Orient the device so that it is upside down facing towards you. The ram panel is in the middle of the device.
    • The screw is at the bottom of the panel.
  2. Acer Aspire 5517-1127 RAM Replacement: adım 2, 2 resimden 1. Acer Aspire 5517-1127 RAM Replacement: adım 2, 2 resimden 2.
    • Using a Phillips screwdriver (PH1), unscrew the screw from the panel.
    • Pull the panel away from the device as shown.
  3. Acer Aspire 5517-1127 RAM Replacement: adım 3, 1 resimden 1.
    • The two tabs are at the top and bottom of the case as shown.
  4. Acer Aspire 5517-1127 RAM Replacement: adım 4, 2 resimden 1. Acer Aspire 5517-1127 RAM Replacement: adım 4, 2 resimden 2.
    • Using two fingers, push the tabs inward to release the RAM from its casing.
    • Pull the RAM towards you to remove it.
  5. Acer Aspire 5517-1127 RAM Replacement: adım 5, 1 resimden 1.
    • The RAM is now removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Newkirk
509 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-1, Blackwell Spring 2017 USF Tampa, Team 17-1, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 402
