Ana içeriğe geç
Acer Aspire 5534-1146 Disc Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 5534-1146 Disc Drive  Replacement, Disc Drive: adım 1, 1 resimden 1.
    • Unscrew the two .8 centimeter screws on the bottom plate with the PH #0 screwdriver.
  2. Acer Aspire 5534-1146 Disc Drive  Replacement: adım 2, 2 resimden 1. Acer Aspire 5534-1146 Disc Drive  Replacement: adım 2, 2 resimden 2.
    • Using your fingers, or the blue plastic spudger tool if needed, remove the plate.
    • Then proceed to unscrew the .4 centimeter Phillips screw on the left side.
  3. Acer Aspire 5534-1146 Disc Drive  Replacement: adım 3, 2 resimden 1. Acer Aspire 5534-1146 Disc Drive  Replacement: adım 3, 2 resimden 2.
    • You can now pull the disk drive out by hand.
  4. Acer Aspire 5534-1146 Disc Drive  Replacement: adım 4, 2 resimden 1. Acer Aspire 5534-1146 Disc Drive  Replacement: adım 4, 2 resimden 2.
    • If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 161
