Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
    • Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
  2. Once you have have removed the back panel cover, find the hard drive’s  location.
    • Once you have have removed the back panel cover, find the hard drive’s location.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Find and locate the two screws that are 0.8cm long  that are holding the hard drive in place to the back metal plate.
    • Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
    • Carefully take a PH #0 screwdriver and remove the two screws.
  5. Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • You are now ready to remove the hard drive from it’s compartment from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 7
Her zaman: 63
