Ana içeriğe geç
Acer Aspire 5734z-4836 Base Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Acer Aspire 5734z-4836 Base Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 2, 1 resimden 1.
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 3, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 3, 2 resimden 2.
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Base Assembly Replacement, Keyboard: adım 4, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement, Keyboard: adım 4, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement, Keyboard: adım 4, 3 resimden 3.
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 5, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 5, 2 resimden 2.
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 6, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 6, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 6, 3 resimden 3.
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
  7. Acer Aspire 5734z-4836 Base Assembly Replacement, Base Assembly: adım 7, 1 resimden 1.
    • Begin with the laptop placed on its bottom and the empty keyboard space facing you.
  8. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 8, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 8, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 8, 3 resimden 3.
    • Disconnect the screen connector in the upper left of the laptop.
  9. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 9, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 9, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 9, 3 resimden 3.
    • Locate the tape on the upper left of the laptop.
    • Peel off the tape, covering the red-and-black wire connector and the white-and-black speaker wires.
  10. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 10, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 10, 2 resimden 2.
    • Gently disconnect the red-and-black wire connector and the white-and-black speaker wires from the upper-left.
  11. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 11, 1 resimden 1.
    • Remove the 5 screws in the middle of the laptop using a #00 Phillips Screwdriver.
    • In order to access the screw in the upper left corner, you may have to gently move the red and white wires.
  12. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 12, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 12, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 12, 3 resimden 3.
    • Disconnect the two blue and white ribbons by applying pressure downward and pushing them out of their sockets.
  13. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 13, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 13, 2 resimden 2.
    • Remove the four screws from the upper corners of the laptop using a Phillips #00 screwdriver.
    • The two metal and two plastic connectors will come free. Save them in a safe place.
  14. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 14, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 14, 2 resimden 2.
    • Pop off the black plastic hinge coverings.
  15. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 15, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Peel away the sticky plastic coverings with tweezers.
  16. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 16, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 16, 2 resimden 2.
    • Remove the three screws with a #00 Philips Screwdriver.
  17. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 17, 1 resimden 1.
    • Remove the single screw next to the right hinge with a #00 Phillips Screwdriver.
  18. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 18, 1 resimden 1.
    • Flip the device so the bottom of the laptop is face-up.
  19. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 19, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 19, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 19, 3 resimden 3.
    • Remove the fifteen screws from the back of the laptop with a Phillips #00 Screwdriver.
  20. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 20, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 20, 2 resimden 2.
    • Pry mid-back panel off.
    • Use a plastic opening tool.
  21. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 21, 1 resimden 1.
    • Lift the hard-drive cover in the bottom right corner off the laptop.
  22. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 22, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 22, 2 resimden 2.
    • Slide down the hard-drive out of the laptop.
  23. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 23, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 23, 2 resimden 2.
    • Peel away the black plastic covering under the mid-back panel.
  24. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 24, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 24, 2 resimden 2.
    • Remove the two screws on the left and bottom of the circuit board with a #00 Phillips Screwdriver.
  25. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 25, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 25, 2 resimden 2.
    • Disconnect the black and white wires on the small circuit board by gently pulling them out of their sockets.
  26. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 26, 2 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 26, 2 resimden 2.
    • Remove the four screws from the metal piece beneath the circuit with a Phillips #000 Screwdriver.
  27. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 27, 1 resimden 1.
    • Life the metal plate free and place it somewhere for safe-keeping.
  28. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 28, 1 resimden 1.
    • The small circuit board will pop up easily. Carefully remove it
  29. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 29, 1 resimden 1.
    • Gently extract the black and white wires. They will pull free from the base through the hole in the upper left corner.
  30. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 30, 3 resimden 1. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 30, 3 resimden 2. Acer Aspire 5734z-4836 Base Assembly Replacement: adım 30, 3 resimden 3.
    • Flip to the front and gently lift the front of the laptop off of the base.
    • Some wires will be pulled up from the base so be careful not to pull it away too quickly.
Sonuç
Holly Steininger
258 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 89
