Ana içeriğe geç
Acer Aspire 5734z-4836 Keyboard Replacement
  1. Acer Aspire 5734z-4836 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Keyboard Replacement: adım 3, 2 resimden 1. Acer Aspire 5734z-4836 Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Keyboard Replacement: adım 5, 2 resimden 1. Acer Aspire 5734z-4836 Keyboard Replacement: adım 5, 2 resimden 2.
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Keyboard Replacement: adım 6, 3 resimden 1. Acer Aspire 5734z-4836 Keyboard Replacement: adım 6, 3 resimden 2. Acer Aspire 5734z-4836 Keyboard Replacement: adım 6, 3 resimden 3.
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Holly Steininger
258 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,534
