Ana içeriğe geç
Acer Aspire 5734z-4836 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: adım 2, 1 resimden 1.
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: adım 3, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 3, 2 resimden 2.
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: adım 4, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement, Screen: adım 4, 2 resimden 2.
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: adım 5, 1 resimden 1.
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: adım 6, 1 resimden 1.
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: adım 7, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 7, 2 resimden 2.
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: adım 8, 1 resimden 1.
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: adım 9, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 9, 2 resimden 2.
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: adım 10, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 10, 2 resimden 2.
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: adım 11, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 11, 2 resimden 2.
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: adım 12, 3 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 12, 3 resimden 2. Acer Aspire 5734z-4836 Screen Replacement: adım 12, 3 resimden 3.
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: adım 13, 2 resimden 1. Acer Aspire 5734z-4836 Screen Replacement: adım 13, 2 resimden 2.
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Susan Cao
121 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-3, Bruce Fall 2016 CSU Fullerton, Team 2-3, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 898
