Ana içeriğe geç
Acer Aspire 5740-5780 Back Cover Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-4 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: adım 1, 2 resimden 1. Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: adım 1, 2 resimden 2.
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Back Cover Replacement: adım 2, 2 resimden 1. Acer Aspire 5740-5780 Back Cover Replacement: adım 2, 2 resimden 2.
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Back Cover Replacement: adım 3, 1 resimden 1.
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Back Cover Replacement: adım 4, 1 resimden 1.
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Back Cover Replacement, Battery: adım 5, 2 resimden 1. Acer Aspire 5740-5780 Back Cover Replacement, Battery: adım 5, 2 resimden 2.
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Back Cover Replacement: adım 6, 1 resimden 1.
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Back Cover Replacement: adım 7, 2 resimden 1. Acer Aspire 5740-5780 Back Cover Replacement: adım 7, 2 resimden 2.
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: adım 8, 2 resimden 1. Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: adım 8, 2 resimden 2.
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Back Cover Replacement: adım 9, 2 resimden 1. Acer Aspire 5740-5780 Back Cover Replacement: adım 9, 2 resimden 2.
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
Sonuç
Dwyer Deighan
358 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G6, Peak Spring 2018 UMass Dartmouth, Team S3-G6, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G6
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 713
