Neye ihtiyacın var
Use spudger to gently pry off open middle cover.
Then flip the middle cover over onto the keyboard.
Adım 7 Prepare Acer Aspire 5740-5780 for Disassembly
Dikkatli ol: adımlar 7-10 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Turn the laptop off and remove the power cord.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
Retrieve the WLAN antenna wire from underneath the keyboard.
Detach the LCD cable from the main board.
