Ana içeriğe geç
Acer Aspire 5740-6378 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 5740-6378 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the locking switch into the unlocked position to ready the battery for removal.
  2. Acer Aspire 5740-6378 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the release latch until the battery pops out.
  3. Acer Aspire 5740-6378 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the battery now that it's been unsecured.
  4. Acer Aspire 5740-6378 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Flip over the device so the back is facing upward.
  5. Acer Aspire 5740-6378 Hard Drive Replacement: adım 5, 2 resimden 1. Acer Aspire 5740-6378 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the five 8.7mm Phillips #0 screws securing the back panel.
  6. Acer Aspire 5740-6378 Hard Drive Replacement: adım 6, 2 resimden 1. Acer Aspire 5740-6378 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the back panel using a spudger or other similar tool to lever it open to reveal the hard drive and other internal components.
  7. Acer Aspire 5740-6378 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the single 3mm Phillips #0 screw that is holding the hard drive in place.
  8. Acer Aspire 5740-6378 Hard Drive Replacement: adım 8, 3 resimden 1. Acer Aspire 5740-6378 Hard Drive Replacement: adım 8, 3 resimden 2. Acer Aspire 5740-6378 Hard Drive Replacement: adım 8, 3 resimden 3.
    • Slide the hard drive away from the connector, then lift it to remove the drive.
Sonuç
Ian Rodriguez
734 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Bailey Spring 2019 UMass Dartmouth, Team S2-G5, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 299
