Ana içeriğe geç
Acer Aspire 5740-6378 WiFi Card Replacement
Neye ihtiyacın var
  1. Acer Aspire 5740-6378 WiFi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the locking switch into the unlocked position to ready the battery for removal.
  2. Acer Aspire 5740-6378 WiFi Card Replacement: adım 2, 1 resimden 1.
    • Slide the release latch until the battery pops out.
  3. Acer Aspire 5740-6378 WiFi Card Replacement: adım 3, 1 resimden 1.
    • Remove the battery now that it's been unsecured.
  4. Acer Aspire 5740-6378 WiFi Card Replacement, WiFi Card: adım 4, 1 resimden 1.
    • Flip over the device so the back is facing upward.
  5. Acer Aspire 5740-6378 WiFi Card Replacement: adım 5, 2 resimden 1. Acer Aspire 5740-6378 WiFi Card Replacement: adım 5, 2 resimden 2.
    • Remove the five 8.7mm Phillips #0 screws securing the back panel.
  6. Acer Aspire 5740-6378 WiFi Card Replacement: adım 6, 2 resimden 1. Acer Aspire 5740-6378 WiFi Card Replacement: adım 6, 2 resimden 2.
    • Use the black spudger to pry open the back panel.
  7. Acer Aspire 5740-6378 WiFi Card Replacement: adım 7, 2 resimden 1. Acer Aspire 5740-6378 WiFi Card Replacement: adım 7, 2 resimden 2.
    • The WiFi card should be directly above the hard drive. Detach the two coaxial connectors attached to the WiFi card by pulling on them.
  8. Acer Aspire 5740-6378 WiFi Card Replacement: adım 8, 1 resimden 1.
    • Remove the two 3mm Phillips #0 screws securing the WiFi card.
  9. Acer Aspire 5740-6378 WiFi Card Replacement: adım 9, 1 resimden 1.
    • Remove the WiFi card.
Sonuç
Ian Rodriguez
734 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Bailey Spring 2019 UMass Dartmouth, Team S2-G5, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 489
