Ana içeriğe geç
Acer Aspire 5742 CMOS Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire 5742 CMOS Battery Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire 5742 CMOS Battery Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire 5742 CMOS Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: adım 2, 3 resimden 1. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: adım 2, 3 resimden 2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: adım 2, 3 resimden 3.
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 CMOS Battery Replacement: adım 3, 3 resimden 1. Acer Aspire 5742 CMOS Battery Replacement: adım 3, 3 resimden 2. Acer Aspire 5742 CMOS Battery Replacement: adım 3, 3 resimden 3.
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: adım 4, 2 resimden 1. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: adım 4, 2 resimden 2.
    • After removing the cover panel, you will see the hard drive, the RAM, and the CMOS battery.
    • The CMOS battery is the silver coin-like object in the center.
  5. Acer Aspire 5742 CMOS Battery Replacement: adım 5, 3 resimden 1. Acer Aspire 5742 CMOS Battery Replacement: adım 5, 3 resimden 2. Acer Aspire 5742 CMOS Battery Replacement: adım 5, 3 resimden 3.
    • Press the tip of the spudger underneath the CMOS battery with very slight force.
    • Press down on the opposite side of the battery while prying the battery upward with the spudger.
    • After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Bill Murray
593 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 UMass Dartmouth, Team 2-6, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G6
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 55
Her zaman: 14,931
