Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Move the battery catch to the "unlocked" position.
Pull back the second spring-loaded battery catch until the battery pops up.
Remove the battery.
Turn the notebook around to face you.
There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
Use a spudger to release the panel from the plastic retaining clips keeping it in place.
Remove the panel and set it aside.
Unscrew the Phillips #00 screw which retains the hard drive in place.
Gently slide the hard drive to the left in order to disengage the SATA connectors.
Lift the drive out of the notebook.
The RAM is protected by a transparent cellophane cover.
Lift this cover away from the RAM. It will not come free from the RAM.
Pull back the retaining clips either side of the RAM.
It will spring up, ready to be removed.
Hold on to opposite edges of the RAM chip and gently pull it diagonally upwards to remove it from the computer.
Repeat steps 5 and 6 for the second RAM chip if necessary.
When reinserting RAM, push it diagonally downwards until almost all of the gold connector strip is inside the socket.
Push gently down on the RAM until the retaining clips click back over it.
The WLAN card is protected by a transparent cellophane cover.
Lift this cover away from the WLAN card. It will not come free from the WLAN card socket.
Use the pointy end of a spudger to remove the antenna connectors from the WLAN card.
There is one Phillips #00 screw keeping the WLAN card attached to the notebook.
Remove this screw.
The WLAN card will spring up from the notebook at an angle.
Just like RAM, hold the WLAN card by the edges and pull it out at an angle.
You might also want to put the antenna cables back in using the flat end of a spudger.
Unfold the laptop so that you are looking at the keyboard.
At the top right of the keyboard you will notice two clips above the 'Del' and 'End' keys.
Using your spudger, press these clips in to unlock the keyboard from the laptop
Slide the spudger along the top of the keyboard until the keyboard is able to easily be lifted up out of the laptop
To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side.
After unlocking both sides of the ZIF connector remove the keyboard for replacement.
Remove the 10 Phillips #0 screws on the bottom cover.
Remove the 4 Phillips #00 screws from under the battery.
Remove the 8 Phillips #0 screws from under the keyboard.
Release the two ribbon cables from the ZIF connectors in the same fashion as in Step 11 with the black spudger.
Once the mechanism is released you may remove the cable by hand.
The plastic cover can now be easily lifted and removed from the rest of the laptop.
Remove the two remaining ribbon cables as described in Step 11.
Remove the display cable with the spudger by pushing each end of the cable out of the connector until it is loose enough to be pulled out by hand.
In a similar fashion as with the display cable use the spudger to remove the two power cables from the motherboard.
Remove the 3 Phillips #0 screws from the fan bracket.
Lift the fan up and place it back down above the heatsink.
The motherboard can be lifted from the side and and then to the right to free the I/O port from the enclosure. Some force may be required to release the heatsink.
Rotate the motherboard to the right and lay it down so that the copper heatsink is facing up and parallel with the bottom of the monitor.
In this position the last cable to the motherboard can be disconnected using the spudger to push each end out until loose enough to pull the cable completely out.
The motherboard can now be completely removed from the laptop enclosure.
Disconect the fan power cable using the spudger to push the connector out.
Remove the fan for replacement or cleaning.
13 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Fantastic guide - thanks so much!!! Mine was a little bit different than yours though:
In step 3, there’s another screw parallel to the hard drive tray screw that holds the top case to the bottom that also needs to come out
In step 13, you also need to unplug the blue and white microphone cable (near the top center screw), not in Step 16 (short wire)
Brilliant guide………….thanks so much ! My laptop kept turning its self off randomly because the fan was so clogged up with dust and fibers. Its now running so cool and problem solved. A great easy to follow idiot guide for the first timers like me. Only took about 45 mins from start to finish. Many many thanks.
