Ana içeriğe geç
Acer Aspire 5742 Hard Drive Removal
Neye ihtiyacın var
  1. Acer Aspire 5742 Hard Drive Removal, Battery: adım 1, 3 resimden 1. Acer Aspire 5742 Hard Drive Removal, Battery: adım 1, 3 resimden 2. Acer Aspire 5742 Hard Drive Removal, Battery: adım 1, 3 resimden 3.
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: adım 2, 3 resimden 1. Acer Aspire 5742 Hard Drive Removal, Cover Panel: adım 2, 3 resimden 2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: adım 2, 3 resimden 3.
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: adım 3, 3 resimden 1. Acer Aspire 5742 Hard Drive Removal: adım 3, 3 resimden 2. Acer Aspire 5742 Hard Drive Removal: adım 3, 3 resimden 3.
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: adım 4, 3 resimden 1. Acer Aspire 5742 Hard Drive Removal, Hard drive: adım 4, 3 resimden 2. Acer Aspire 5742 Hard Drive Removal, Hard drive: adım 4, 3 resimden 3.
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Skylar MacDonald
1.964 İtibar
5 adet Kılavuz yazıldı
4 Yorum
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Yanıt
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Yanıt
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 69
Her zaman: 45,298
