Ana içeriğe geç
Acer Aspire 5742G Memory stick Replacement
Neye ihtiyacın var
Videoya Genel Bakış
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: adım 1, 1 resimden 1.
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: adım 2, 1 resimden 1.
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: adım 3, 2 resimden 1. Acer Aspire 5742G Memory stick Replacement: adım 3, 2 resimden 2.
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: adım 4, 1 resimden 1.
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: adım 5, 1 resimden 1.
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Petter Berget
740 İtibar
3 adet Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
156 Üyeler
292 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 767
