Ana içeriğe geç
Acer Aspire 5749 Fan/HeatSink Replacement
Neye ihtiyacın var
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: adım 1, 3 resimden 1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: adım 1, 3 resimden 2. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: adım 1, 3 resimden 3.
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. Acer Aspire 5749 Fan/HeatSink Replacement: adım 2, 3 resimden 1. Acer Aspire 5749 Fan/HeatSink Replacement: adım 2, 3 resimden 2. Acer Aspire 5749 Fan/HeatSink Replacement: adım 2, 3 resimden 3.
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: adım 3, 3 resimden 1. Acer Aspire 5749 Fan/HeatSink Replacement: adım 3, 3 resimden 2. Acer Aspire 5749 Fan/HeatSink Replacement: adım 3, 3 resimden 3.
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
JeanChristophe
523 İtibar
3 adet Kılavuz yazıldı
5 Yorum
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - Yanıt
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - Yanıt
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - Yanıt
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 7,626
