Ana içeriğe geç
Acer Aspire 5750-6667 Optical Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 5750-6667 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire 5750-6667 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Optical Drive Replacement: adım 2, 3 resimden 1. Acer Aspire 5750-6667 Optical Drive Replacement: adım 2, 3 resimden 2. Acer Aspire 5750-6667 Optical Drive Replacement: adım 2, 3 resimden 3.
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 1. Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Locate the black screw just above the battery.
    • Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
  4. Acer Aspire 5750-6667 Optical Drive Replacement: adım 4, 2 resimden 1. Acer Aspire 5750-6667 Optical Drive Replacement: adım 4, 2 resimden 2.
    • Pull the optical drive free from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,206
