Ana içeriğe geç
Acer Aspire 5750-6677 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire 5750-6677 Motherboard Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Flip the laptop over.
  2. Acer Aspire 5750-6677 Motherboard Replacement: adım 2, 1 resimden 1.
    • Place a screw driver in the orange tab then slide to the right.
  3. Acer Aspire 5750-6677 Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift and remove the battery.
  4. Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: adım 4, 2 resimden 1. Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Flip the device over so the backside is facing up.
    • Remove the two screws with the Phillips #0 screwdriver.
  5. Acer Aspire 5750-6677 Motherboard Replacement: adım 5, 2 resimden 1. Acer Aspire 5750-6677 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the cover to access the hard drive.
  6. Acer Aspire 5750-6677 Motherboard Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #0, remove the two screws holding the hard drive in.
  7. Acer Aspire 5750-6677 Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull the tab and lift up to remove the hard drive.
  8. Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Start by flipping the device over to expose the screws.
    • Remove ten screws with the Phillips #0 screwdriver.
  9. Acer Aspire 5750-6677 Motherboard Replacement: adım 9, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the four screws found under the battery.
  10. Acer Aspire 5750-6677 Motherboard Replacement: adım 10, 2 resimden 1. Acer Aspire 5750-6677 Motherboard Replacement: adım 10, 2 resimden 2.
    • Flip the laptop back around so the Acer logo is facing upwards.
    • Open the laptop and using the iFixit opening tool, press the tabs in at the very top of the keyboard, in order to remove the keyboard.
  11. Acer Aspire 5750-6677 Motherboard Replacement: adım 11, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove six screws.
    • Pull the top off of the keyboard to expose the motherboard.
  12. Acer Aspire 5750-6677 Motherboard Replacement: adım 12, 3 resimden 1. Acer Aspire 5750-6677 Motherboard Replacement: adım 12, 3 resimden 2. Acer Aspire 5750-6677 Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the seven screws using the Phillips #0 screwdriver.
    • Detach any wires or cables that are attached to the motherboard.
    • Remove the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dean Smith
207 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Valliere Fall 2019 UMass Dartmouth, Team S1-G3, Valliere Fall 2019 üyesi
UMASSD-VALLIERE-F19S1G3
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,757
