Giriş
This guide will show you how to replace the memory in your Acer Aspire 6530-6522. You will need to do this f you are upgrading to more memory, or if your memory has become damaged or faulty and you have a new one.
Neye ihtiyacın var
Make sure the device is unplugged and completely powered down.
Turn the device over.
Using a Phillips #1 screwdriver, remove the nine 7mm screws holding the back panel.
Bir başkası bu kılavuzu tamamladı.
