Ana içeriğe geç
Acer Aspire 7736Z-4809 Back Panel Removal
Neye ihtiyacın var
  1. Acer Aspire 7736Z-4809 Back Panel Removal, Acer Aspire 7736Z-4809 Repair Preparation: adım 1, 1 resimden 1.
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Back Panel Removal: adım 2, 1 resimden 1.
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: adım 3, 2 resimden 1. Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: adım 3, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Back Panel Removal: adım 4, 3 resimden 1. Acer Aspire 7736Z-4809 Back Panel Removal: adım 4, 3 resimden 2. Acer Aspire 7736Z-4809 Back Panel Removal: adım 4, 3 resimden 3.
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Back Panel Removal: adım 5, 1 resimden 1.
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
Sonuç
Pnithan Jantarakolica
1.153 İtibar
10 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G4
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 498
