Ana içeriğe geç
Acer Aspire 7736Z-4809 CPU Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: adım 1, 1 resimden 1.
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 2, 1 resimden 1.
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: adım 3, 2 resimden 1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: adım 3, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 4, 3 resimden 1. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 4, 3 resimden 2. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 4, 3 resimden 3.
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 5, 1 resimden 1.
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: adım 6, 3 resimden 1. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: adım 6, 3 resimden 2. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 7, 2 resimden 1. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 7, 2 resimden 2.
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 8, 3 resimden 1. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 8, 3 resimden 2. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 8, 3 resimden 3.
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: adım 9, 1 resimden 1.
    • Install the modified or new cooling fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Pnithan Jantarakolica
1.153 İtibar
10 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G4
5 Üyeler
Bir Yorum
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 26
Her zaman: 945
