Ana içeriğe geç
Acer Aspire 7736Z-4809 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire 7736Z-4809 Hard Drive Replacement, Acer Aspire 7736Z-4809 Repair Preparation: adım 1, 1 resimden 1.
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: adım 3, 2 resimden 1. Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: adım 3, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 4, 3 resimden 1. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 4, 3 resimden 2. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the 3.5mm Phillips #1 screw.
  7. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 7, 2 resimden 1. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 7, 2 resimden 2.
    • Slide the bracket towards you to release it from the frame.
  8. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 8, 3 resimden 1. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 8, 3 resimden 2. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 8, 3 resimden 3.
    • Use the black tab to pull the hard drive up and out of the laptop.
  9. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 9, 2 resimden 1. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the four 3.5 Phillips #1 screws.
  10. Acer Aspire 7736Z-4809 Hard Drive Replacement: adım 10, 1 resimden 1.
    • Remove the hard drive from the bracket and install the new hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Pnithan Jantarakolica
1.153 İtibar
10 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G4
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,191
