Ana içeriğe geç
Acer Aspire 7736Z-4809 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  2. Acer Aspire 7736Z-4809 RAM Replacement: adım 2, 3 resimden 1. Acer Aspire 7736Z-4809 RAM Replacement: adım 2, 3 resimden 2. Acer Aspire 7736Z-4809 RAM Replacement: adım 2, 3 resimden 3.
    • Remove the back panel of the laptop.
  3. Acer Aspire 7736Z-4809 RAM Replacement: adım 3, 1 resimden 1.
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  4. Acer Aspire 7736Z-4809 RAM Replacement, RAM: adım 4, 3 resimden 1. Acer Aspire 7736Z-4809 RAM Replacement, RAM: adım 4, 3 resimden 2. Acer Aspire 7736Z-4809 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Release the tabs on the RAM by bending the tabs away from the RAM.
    • The RAM will rise upwards at an angle.
  5. Acer Aspire 7736Z-4809 RAM Replacement: adım 5, 2 resimden 1. Acer Aspire 7736Z-4809 RAM Replacement: adım 5, 2 resimden 2.
    • Pull the RAM out of the slot.
    • If you are replacing both sticks of RAM, repeat the previous step for removing the RAM.
Sonuç
Pnithan Jantarakolica
1.153 İtibar
10 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G4
5 Üyeler
2Kılavuz Yorumları
“supports the DDR2 667MHz memory,240-pin soDIMM RAM “
It’s a laptop and what you are holding is a 200-pin soDIMM RAM module.
BaronDRS - Yanıt
Not only is it 200-pin soDIMM module instead of a 240-pin soDIMM module, it's a pc2-6400 (800MHz) and not a pc2-5300 (667MHz).
1videopirate - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 700
