Ana içeriğe geç
Acer Aspire 7741Z-4643 RAMReplacement
Neye ihtiyacın var
  1. Acer Aspire 7741Z-4643 RAMReplacement, RAM: adım 1, 3 resimden 1. Acer Aspire 7741Z-4643 RAMReplacement, RAM: adım 1, 3 resimden 2. Acer Aspire 7741Z-4643 RAMReplacement, RAM: adım 1, 3 resimden 3.
    • Begin with the bottom of the laptop facing up.
    • With a screwdriver, unscrew the four phillips #0 7.5mm screw around the bottom panel.
    • Lift the panel at the top and pull towards you to remove it from the laptop.
  2. Acer Aspire 7741Z-4643 RAMReplacement: adım 2, 3 resimden 1. Acer Aspire 7741Z-4643 RAMReplacement: adım 2, 3 resimden 2. Acer Aspire 7741Z-4643 RAMReplacement: adım 2, 3 resimden 3.
    • The memory should be to the right, after you have removed the bottom panel.
    • Towards the bottom of the memory card, push outwards on the two small silver levers to release the memory card.
    • Pull the memory card out towards you to remove it.
Sonuç
Amy Endo
186 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S11-G4, Lore Fall 2018 UC Davis, Team S11-G4, Lore Fall 2018 üyesi
UCD-LORE-F18S11G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 445
