Ana içeriğe geç
Acer Aspire 774G-58GS Thermal Paste Replacement
Neye ihtiyacın var
  1. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: adım 1, 3 resimden 1. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: adım 1, 3 resimden 2. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: adım 1, 3 resimden 3.
    • Remove the three screws from the plate that covers the RAM and HDD using a Phillips #0 screwdriver.
    • Remove the plate from the laptop.
  2. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 2, 2 resimden 1. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 2, 2 resimden 2.
    • Remove the DVD drive and the three screws that are underneath it.
    • Remove all the screws surrounding the backplate.
  3. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 3, 3 resimden 1. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 3, 3 resimden 2. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 3, 3 resimden 3.
    • Disconnect the speaker wire beneath the RAM.
    • Gently remove the backplate from the laptop.
  4. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 4, 2 resimden 1. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 4, 2 resimden 2.
    • Remove the five screws from the heat sink.
    • Take a cotton ball and dab it with isopropyl alcohol.
    • Use the cotton ball to wipe the old thermal paste from the heat sink.
  5. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 5, 3 resimden 1. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 5, 3 resimden 2. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 5, 3 resimden 3.
    • Take another cotton ball, dab it with isopropyl alcohol, and gently wipe the thermal paste off of the GPU and CPU.
    • There is no need to rub hard as it should come off with ease.
    • Once the thermal paste is completely off, let the heat sink dry for a couple of minutes.
    • Apply a dab of new thermal paste in the middle of the CPU and GPU.
    • Corsair TM30 thermal paste is used in this guide.
  6. Acer Aspire 774G-58GS Thermal Paste Replacement: adım 6, 1 resimden 1.
    • Put the heatsink back on and screw it in place.
Sonuç
Abdul Munam Khan
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 511
