Ana içeriğe geç
Acer Aspire 8735G Memory (RAM) Replacement
Neye ihtiyacın var
  1. Acer Aspire 8735G Memory (RAM) Replacement, Battery: adım 1, 1 resimden 1.
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Memory (RAM) Replacement: adım 2, 1 resimden 1.
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Memory (RAM) Replacement: adım 3, 1 resimden 1.
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Memory (RAM) Replacement: adım 4, 1 resimden 1.
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Acer Aspire 8735G Memory (RAM) Replacement, RAM: adım 5, 1 resimden 1.
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws. After that you are in.
  6. Acer Aspire 8735G Memory (RAM) Replacement: adım 6, 1 resimden 1.
    • Now try to spot the Memory, which is here indistinguishable as a red circle.
  7. Acer Aspire 8735G Memory (RAM) Replacement: adım 7, 1 resimden 1.
    • Don't remove the ram before pushing the pins.
    • After the previous step, remove the ram by pushing the pins holding it outwards.
  8. Acer Aspire 8735G Memory (RAM) Replacement: adım 8, 1 resimden 1.
    • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
    • After that the pins jump up and you can carefully remove the ram.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Regome
794 İtibar
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 213
