Giriş
Use this guide to replace the battery in your Acer Aspire A515-51G Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
Remove the HDD hatch.
Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
Use tweezers, or your fingers, to peel back the tape connecting the battery to the motherboard.
Use a Phillips screwdriver to remove the two 4.5 mm-long screws securing the battery.
Pull the battery towards the top of the laptop to release its plastic clips.
Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
