Ana içeriğe geç
Acer Aspire AS3810TZ-4806 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire AS3810TZ-4806 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Unlock the battery release by sliding it to the right.
  2. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the release button and remove the battery.
  3. Acer Aspire AS3810TZ-4806 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Make sure your device is powered off and the battery is removed.
  4. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the three Phillips screws on the hard drive cover so the cover may be removed.
  5. Acer Aspire AS3810TZ-4806 Hard Drive Replacement: adım 5, 1 resimden 1.
    • After the cover is removed, remove the hard drive from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 125
