Ana içeriğe geç
Acer Aspire E1-470P-6659 LCD Panel & Faceplate Replacement
Neye ihtiyacın var
  1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 3, 3 resimden 1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 3, 3 resimden 2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 3, 3 resimden 3.
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 4, 3 resimden 1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 4, 3 resimden 2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 4, 3 resimden 3.
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement, LCD Panel & Faceplate: adım 5, 1 resimden 1.
    • Locate the screws connected to the hinge of the laptop. Small, black stickers hide them from immediate view.
  6. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 6, 3 resimden 1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 6, 3 resimden 2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 6, 3 resimden 3.
    • On both corners, use tweezers to remove small plastic sticker hiding the screws.
    • Remove screws using Phillips #0 screwdriver.
  7. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 7, 3 resimden 1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 7, 3 resimden 2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 7, 3 resimden 3.
    • Turn the laptop over and open it up.
    • Using a prying tool, run along all edges of the display to pry the front face plate from the cover.
    • Use your fingers to pull the LCD panel and faceplate from the backing.
  8. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 8, 3 resimden 1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 8, 3 resimden 2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 8, 3 resimden 3.
    • LCD with faceplate should separate, be careful not to pull completely away because there is a cable still attached to the display.
    • Carefully peel tape away from cable lead and separate cable from LCD panel.
  9. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: adım 9, 1 resimden 1.
    • Remove the LCD Panel and faceplate from the device.
Sonuç
Joel Humes
163 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S4-G5, Lore Fall 2018 UC Davis, Team S4-G5, Lore Fall 2018 üyesi
UCD-LORE-F18S4G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Need more guide how to safe instal lcd, cause peel tape and need new one.. Overall good and detail love it
Kusuma Wijaya - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 515
