Ana içeriğe geç
Acer Aspire E1-470P-6659 Cooling Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 3, 3 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 3, 3 resimden 2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 4, 3 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 4, 3 resimden 2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: adım 5, 2 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 6, 3 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 6, 3 resimden 2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 6, 3 resimden 3.
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 7, 2 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 8, 1 resimden 1.
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 10, 1 resimden 1.
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: adım 11, 3 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: adım 11, 3 resimden 2. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: adım 11, 3 resimden 3.
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 12, 2 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 12, 2 resimden 2.
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
  13. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: adım 13, 2 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: adım 13, 2 resimden 2.
    • Flip the motherboard and fan piece over.
    • Remove the four screws using the Phillips #000 Screwdriver.
  14. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 14, 3 resimden 1. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 14, 3 resimden 2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: adım 14, 3 resimden 3.
    • Flip the motherboard over and slowly remove the tape holding the cooling fan down.
    • Use a spudger to remove the top of the fan from the base of the fan.
    • Remove the cooling fan component from both the tape and the motherboard.
Sonuç
Faith Lobaton
497 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S4-G5, Lore Fall 2018 UC Davis, Team S4-G5, Lore Fall 2018 üyesi
UCD-LORE-F18S4G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 379
