Ana içeriğe geç
Acer Aspire E1-510-2500 RAM Card Replacement
Neye ihtiyacın var
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: adım 2, 2 resimden 1. Acer Aspire E1-510-2500 RAM Card Replacement: adım 2, 2 resimden 2.
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: adım 3, 2 resimden 1. Acer Aspire E1-510-2500 RAM Card Replacement: adım 3, 2 resimden 2.
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: adım 4, 2 resimden 1. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: adım 4, 2 resimden 2.
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: adım 5, 2 resimden 1. Acer Aspire E1-510-2500 RAM Card Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: adım 6, 3 resimden 1. Acer Aspire E1-510-2500 RAM Card Replacement: adım 6, 3 resimden 2. Acer Aspire E1-510-2500 RAM Card Replacement: adım 6, 3 resimden 3.
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: adım 7, 2 resimden 1. Acer Aspire E1-510-2500 RAM Card Replacement: adım 7, 2 resimden 2.
    • Carefully remove the RAM card from its home.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sebastian Taylor
733 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Julie Fall 2017 UMass Dartmouth, Team S2-G5, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S2G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 567
