Ana içeriğe geç
Acer Aspire E1-510P-4637 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire E1-510P-4637 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 6, 2 resimden 1. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 7, 3 resimden 1. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 7, 3 resimden 2. Acer Aspire E1-510P-4637 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Caleb lindsay
778 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-15, Maness Spring 2016 Cal Poly, Team 34-15, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G15
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,928
