Giriş
Device not charging or not lasting a long time on a charge? This guide will show you how to remove and replace the battery on an Acer Aspire E1-531-2438.
Neye ihtiyacın var
Turn the device over so the back side is facing up.
Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
Bir başkası bu kılavuzu tamamladı.
