Giriş
Screen dim, has lines across it, dead pixels. This guide will guide you on how to replace the screen on an Acer Aspire E1-531-2438.
Neye ihtiyacın var
Turn the device over so the back side is facing up.
Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
Using a Phillips #0 screwdriver, remove all of the following screws:
Fifteen 9mm screws
One 6mm screw
Three 3.5mm screws
Using a plastic opening tool, pry along the seam running the perimeter of the laptop to separate the bottom case from the palmrest assembly.
Flip the device over and open the laptop so that the keyboard is visible.
Lift up the palmrest assembly just far enough to access the connectors underneath.
Bir başkası bu kılavuzu tamamladı.
