Ana içeriğe geç
Acer Aspire E1-531-2438 Wifi Card Replacement
Neye ihtiyacın var
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 2, 1 resimden 1.
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: adım 3, 2 resimden 1. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 4, 3 resimden 1. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 4, 3 resimden 2. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 4, 3 resimden 3.
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 5, 1 resimden 1.
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 6, 2 resimden 1. Acer Aspire E1-531-2438 Wifi Card Replacement: adım 6, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
Sonuç
Jakob Rinkus
965 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 UMass Dartmouth, Team S8-G2, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 922
