Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will provide steps to replace the hard drive of a Acer Aspire E1-532-2616.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a Phillips screwdriver to remove the  CM2.5*3 screw on the shown cover. Lift and remove the cover from the side that had the holdinging screw.
    • Use a Phillips screwdriver to remove the CM2.5*3 screw on the shown cover.
    • Lift and remove the cover from the side that had the holdinging screw.
    • Lifting the plastic cover will require some pressure.
  2. Unscrew the two  CM2*3-4 screws that attach the hard drive to the Laptop.
    • Unscrew the two CM2*3-4 screws that attach the hard drive to the Laptop.
  3. Push the hard drive away from where the screws were (to the left, if referring to the picture). The hard drive will slide to the left, allowing it to be safely removed.
    • Push the hard drive away from where the screws were (to the left, if referring to the picture).
    • The hard drive will slide to the left, allowing it to be safely removed.
Sonuç
Bir Yorum
Hello! Is it possible to recover data from it? My laptop is dead and I don't know how I could recover my files.. I'm not good in computers :D thank you in advance!
Andri HaiHui - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 12
Son 30 gün: 63
Her zaman: 887
