Ana içeriğe geç
Acer Aspire E1-532-2616 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire E1-532-2616 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Acer Aspire E1-532-2616 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove the CM2.5*3 screw on the shown cover.
    • Lift and remove the cover from the side that had the holdinging screw.
    • Lifting the plastic cover will require some pressure.
  2. Acer Aspire E1-532-2616 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Unscrew the two CM2*3-4 screws that attach the hard drive to the Laptop.
  3. Acer Aspire E1-532-2616 Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire E1-532-2616 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Push the hard drive away from where the screws were (to the left, if referring to the picture).
    • The hard drive will slide to the left, allowing it to be safely removed.
Sonuç
Bir Yorum
Hello! Is it possible to recover data from it? My laptop is dead and I don't know how I could recover my files.. I'm not good in computers :D thank you in advance!
Andri HaiHui - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 2,114
