Giriş
If the audio from your Acer Aspire E1-572-6829 sounds distorted, the speakers may need replacing. This guide walks you through how to locate and replace the speakers in your Acer Aspire E1-572-6829 laptop.
The speakers allow your device to have sound. Over time they may fill with dust or dirt, which can distort the sound. Check our troubleshooting page for tips on how to clean your speakers. If that doesn't solve the issue, you may need to replace your speakers.
Make sure that your device is powered off and the charger is unplugged before beginning the steps in this guide.
Neye ihtiyacın var
Flip the laptop over so that you are facing the back panel.
Locate the battery lock switch below the battery.
Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
Use a plastic spudger to pry open the lower back panel from its top edge.
Lift the panel up and out to remove it.
Detach the two cables connected to the Wi-Fi card. Gently pull them off using a plastic pry tool or your fingers.
Use a Phillips #0 screwdriver to remove the eleven 5 mm screws that secure the motherboard.
Slide out the optical disk drive to the right side to remove it.
Unplug the ZIF connector by using a plastic spudger or your finger to lift the locking flap before gently pulling it out.
Use a plastic spudger or your fingers to flip the metal clip over and then gently pull the display cable connector out.
Unplug the no-fuss ribbon cables by pulling them straight out of the connector using your fingers.
Carefully lift the motherboard up from the bottom edge and slide it down to dislodge it from the case.
Carefully flip the motherboard over.
Unplug the connector on the bottom of the motherboard by using your fingers to gently pull it out.
The motherboard can now be safely removed from the laptop.
