Ana içeriğe geç
Acer Aspire E3-111-C0WA Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 2, 3 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 2, 3 resimden 2. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 2, 3 resimden 3.
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 4, 3 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 4, 3 resimden 2. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 4, 3 resimden 3.
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 5, 2 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 6, 2 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement: adım 6, 2 resimden 2.
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
Sonuç
Jonathan Chandler
503 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 594
